Mar 27, 2015 4:27 PM UTC
Save a Copy using J-link
Hi!
Has anyone used the J-link to Save a Copy?
I want to use this to make the copied items stay in the same encoding as in the example.
Thanks!
Jun 15, 2016 3:31 PM UTC
I wanted a 'save a copy' method too, but couldn't find one.
Jun 20, 2016 8:16 PM UTC
I used the following function:
ModelDescriptor_CreateFromFileName
static ModelDescriptorModelDescriptor_CreateFromFileName (String FileName)
    Creates a new model descriptor object, given a file name string.
See Also:
ModelDescriptor.GetFileName(), pfcModel.ModelDescriptor_Create(ModelType, String, /*optional*/ String), BaseSession.GetModelFromFileName(String), BaseSession.RetrieveModel(ModelDescriptor)
Manual References:
Models: Model Descriptors, Models: Model Descriptors
Parameters:
FileName
The file name, of the form "<name>.<extension>".
Returns:
The new model descriptor object.
and it is working 😉
