Save model
  • September 5, 2024
  • 2 replies
  • 802 views
Hello all,
I am saving a step file using ProIntf3DFileWrite() but I lose all colors assigned to parts and features. They are all set to grey by default. Is there any setting/config options I need to change before saving the model?
Or any alternative method to save .asm/step file without losing colors assigned?
KenFarley
A simple search yields the following as the first result:
https://community.ptc.com/t5/PTC-Education-Forum/How-to-Create-STEP-file-with-Colors-from-Creo-Parametric/td-p/10975
This tells how to output a STEP file in a format that supports colors. There are a number of versions of STEP file, apparently with different capabilities.
You'll have to figure out how to use the functions you are implementing to output a file with the settings detailed in the discussion. Hopefully the toolkit stuff you are using has enough descriptive comments for you to do so.
Community Moderator
September 12, 2024
Hello @Marcusanthony,
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
