Feb 9, 2016 2:19 PM UTC
SDK in Creo 3 Trial
Hi All,
In the Trial version of PTC Creo, where is the Software Development Kit ?
Where can i find it?
I want to use the VB API.
Feb 9, 2016 9:58 PM UTC
I assume you're talking about Creo Parametric 3.0, which does have a Visual Basic API.  I currently have Creo Parametric 3.0 Build M070 installed, but it's not a trial version. I don't know if PTC offers the VB API with trial installation disks.
I have the Visual Basic API is located under
Common Files\vbapi
As I remember, this was an optional module when I installed it.
|+|  M a r k  |+|
qazerty1-VisitorAuthor
Feb 10, 2016 7:39 AM UTC
Hi.
Yes i talk about Creo Parametric 3.0.
I dont' have "vbapi" folder and in my setup I did not find the option to install the VB API.
Do you have any idea?
Feb 10, 2016 4:08 PM UTC
You'll need to ask PTC about this. You should tell them that you want to include the Visual Basic API as in your evaluation of Creo Parametric 3.0.
|+|  M a r k  |+|
