Nov 30, 2021 9:59 AM UTC
Selection location box on startup
Any ideas how to disable this please
Dec 1, 2021 7:26 AM UTC
What do you mean? Do you want to set the position to (0,0)?
Dec 1, 2021 8:10 AM UTC
I don't know what it is. I would prefer it not to show on launch of creo.
Dec 1, 2021 8:16 AM UTC
rename all config.pro files to config.pro_renamed and start Creo.
Dec 1, 2021 9:13 AM UTC
how does renaming my config file fix this please.
Dec 1, 2021 9:50 AM UTC
if you use Creo Parametric then renaming config.pro will tell you whether the problem is "hidden" inside config.pro.
RPN
18-Opal
Dec 1, 2021 7:29 PM UTC
The last place for check are you environment vars, maybe there is a different between the default ones, open cmd shell and enter set, or the ones in Creo, open a system window and enter set as well.
Check for proTk.dat and creoTk.dat as well, because your hitachi env is not the default one 🙂
