2-Explorer
Nov 16, 2018 11:56 AM UTC
Selection object to feature in toolkit
Hello
I have selection object chosen from user using API proselect(). Here, user is allowed to select csys only. What I need is feature handle for this csys. For the same, I am doing selection to modelitem ProSelectionModelitemGet() and on this model item, I am doing geom item to csys with API ProGeomitemToCsys(). Now with procsys, I am not able to directly use it as profeature.
Is there any other way or I am missing something to get feature handle from selection object?
Thanks and Regards
Ketan
FV_01
FV_01Answer
Nov 16, 2018 1:35 PM UTC
@Ketan_Lalcheta wrote:
Hello
Thanks and Regards
Ketan
Hi all,
Ketan, do not cast... The Pro/Toolkit way is:
ProSelectionModelitemGet(…) ;
if( PRO_FEATURE != mi.type)  { ProGeomitemFeatureGet(…);}
HIH.
FV.
Nov 16, 2018 12:00 PM UTC
ProModelitem can be directly type casted to ProFeature right ?
2-Explorer
Nov 16, 2018 12:06 PM UTC
Yes that is what I tried first as both are having same structure, but direct type cast failed.
FV_01
FV_0117-PeridotAnswer
Hello
Thanks and Regards
Ketan
Hi all,
HIH.
FV.
RPN
18-Opal
Nov 16, 2018 10:03 PM UTC
Or select a feature and use the filter function to validate that a csys was selected.
Nov 19, 2018 3:07 AM UTC
Hi @Ketan_Lalcheta
Using API ProSelect(),setting select filter as "csys",then change selection to modelitem by ProSelectionModelitemGet() .
Now, you get :
modelitem's type is PRO_CSYS,
modelitem's ID is "Geometry ID"
But, Feature Id not equal to Geometry Id.
So, you can't cast it directly.
if you want the Feature handle.
After doing ProSelectionModelitemGet(), just using ProGeomitemFeatureGet().
then you can get the Feature handle which construct the csys.
