Aug 25, 2011 8:23 AM UTC
Set datum show/hide status using ProToolkit.
Anybody here is aware of a way or API to control show/hide status of dayum planes/axes in ProE WF 5.0 M060?
Aug 25, 2011 9:07 AM UTC
Simply get the status of the config.pro options (display_axes,
display_points and so on). Their current status is being changed (true or
false) when the user presses the icons in the menu bar.
Andreas
Sep 1, 2011 4:07 PM UTC
Rahul,
Use ProModelitemHide() and ProModelitemUnhide().
Patrick Williams | Engineering Systems | o: 616.698.3766 | c: 616.947.2110
[cid:image001.jpg@01CC689F.AE518A90]
Sep 2, 2011 7:09 PM UTC
Does anyone know if the ProModelitemIsHidden API works in WF4? It is not giving me correct results.
I am traversing through all the layers (ProMdlLayersCollect) and need to keep track of layer names and if each layer is hidden. No problems getting the layer names (ProModelitemNameGet), but when I added the hidden status check (ProModelitemIsHidden), it does nothing. The return data is PRO_B_FALSE for all layers and the return code is PRO_TK_NO_ERROR. Most of my layers ARE hidden.
Has this happened for anyone else?
Sharon
Sep 5, 2011 8:18 AM UTC
In Reply to Sharon Barber:
Sharon
I had some luck with ProLayerDisplayStatusGet, but I'm not sure if your traversal supports this approach.
Sep 5, 2011 8:28 AM UTC
The HIDDEN status is different from the layer status.
Items/Features are hidden if the user hides an element/item by clicking with the
right mouse button on the item in the model tree or graphics window and select
"hide" or "unhide".
The layer status is an additional setting and Tookit can read the layer status
(shown or blanked). And you can check which elements are on the layer.
So with ProModelitemIsHidden you cannot check if a layer is blanked=hidden.
Andreas
Sean Geggie <sean@luxion.com> hat am 5. September 2011 um 10:18 geschrieben:
> > Does anyone know if theProModelitemIsHiddenAPI works in WF4? It is not
> > Thanks,
> > Sharon
> Site Links:View post online
DomenicLaritz
Sep 5, 2011 8:31 AM UTC
Why don't you use the functions ProLayerDisplaystatusGet and ProLayerDisplaystatusSet?
Regards, Domenic
