Setting element value
Hello all,
In pattern table the  instance values are set using ProElementIntegerSet or ProElement DoubleSet(). But sometimes I want to ignore some Instances in pattern table by adding @ symbol in idx column. How can I set value to @ so that the instance is ignored and read as comment?
Community Moderator
Hi @Sss4598,
Thank you for your question.
Anurag
