setting web_link_security_autoprompt in config.pro
Hi there,
I am trying to get rid of security warnings within Creo's own chromium browser, when visiting Web.Link enabled Websites (e.g. Windchill).
Activating "remember my decision" only works until Creo or chromium is restarted.
I tried
web_link_security_autoprompt no
but it does not seem to have an effect on that.
Any suggestions?
sjurajAnswer
From weblink guide (Creo 7):
New Security Warning While Using Chromium
Browser
A new security warning message is added for the Chromium browser. Every time
the Chromium browser loads a web page that tries to access Web.Link methods
and objects, the warning message appears. You are prompted to confirm if you
want to access the Web.Link application from the web page.
So you can check Remebmber decision. If this windows will appear anywat try to check Remember decition and then create new customizacion.ui file to load at the start of Creo.
please ask PTC Support.
sjuraj15-MoonstoneAnswer
Browser
Mat16-PearlAuthor
unfortunately, that did it.
I am not a big fan of PTC's policy to throw more and more of Creo's configuration into a binary creo_parametric_customization.ui file.
e.g. If You, as an administrator, want to roll out changes to the appearance (e.g. model tree columns), this seems no longer possible without overwriting the user's own configuration (e.g. customized button layout), which is also stored in creo_parametric_customization.ui.
Or is there a way to "merge" two creo_parametric_customization.ui files?
it is possible https://www.ptc.com/en/support/article/CS54928
but it depends on how you distribute changes across users
