Showing combined State view with annoations in the CAD drawing
- 2 replies
- 1666 views
- Translate All
Software used: Creo 8.0.
When I set up combined state view in the model I can show different dimensions and annotations in each combined state view, but when add a new view to the drawing and select the combined state view, the annotations and dimensions are not displayed in the drawing as they are in the model.
When I select show model annotations for the drawing view it shows every single dimension available not just the annotations and dimension I displayed in the Model according to the combined state view.
In older versions of Creo, this was possible, not sure if there is a setting that should be changed in new versions.
