8-Gravel
Feb 15, 2013 9:47 AM UTC
Simplified representation in parts using Pro/TOOLKIT
there ist a note in the tkuse.pdf for Wildfire 4.0 that
Pro/TOOLKIT supports simplified representations of assemblies only, not parts?
Really???
Is there no way to create and define a simplified representation for parts?
greetings Lars
Feb 15, 2013 3:07 PM UTC
According to the documentation that is correct. Through Pro/TOOLKIT you cannot define a simprep for a part.
Function ProSimprepCreate
Description
Creates a simplified representation based on the supplied data.
NOTE:
Operates on assemblies only, not parts.
Synopsis
#include <prosimprep.h<prosimprep_h.html>>
ProError<protoolkiterrors_h.html#proerror>
ProSimprepCreate
ProSolid<proobjects_h.html#prosolid> p_solid
/* (In)
The solid in which to create the simplified representation
ProSimprepdata<prosimprepdata_h.html#prosimprepdata>* p_data
/* (In)
The data for the simplified representation
ProSimprep<proobjects_h.html#prosimprep>* p_new_rep
/* (Out)
The handle to the new simplified representation
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image001.jpg@01CE0B5B.E2199560]
3-Newcomer
Oct 10, 2018 6:51 AM UTC
I need the same functionality.
How can we increase the relevance of this issue?
8-Gravel
Feb 18, 2013 7:21 AM UTC
Hello Patrick,
yes, I read the note.
But ProSimnrepCreate works on parts. 🙂
So I thought it might work...
Thanks Lars
Oct 23, 2018 2:10 PM UTC
Hi, I think it is not supported but it may work. Actually  it could have the consequence that something / for example sections and x-hatching of the simplified parts  in the drawing view could not work or will lead to the wrong results. I could remember that there are some kind  of such side effects.
One alternative way for the simplified representation of parts is to  use substitute simplified representation of  components where the simplification is done via part family table.
