SmartAssembly REPLACE SKELETON
I made a Skeleton family table
I Need to replace a skeleton with an other instance.
REPLACE_COMPONENT works with Part but this not Works with Skeleton
Do you have an idea to made this?
Thank's
TomU
TomUAnswer
Seems like it should work.   Manually using 'Replace' works fine in Creo for swapping skeleton family table instances.  You will probably need to open a case with Sigmaxim tech support and ask them why it's not working.
TomU
TomU23-Emerald IVAnswer
AHardy1-VisitorAuthor
thank's i open ticket to Sigmaxim
just for information, SIGMAXIM said it's not possible to REPLACE Skeleton with SMART ASSEMBLY
