7-Bedrock
May 6, 2026 8:32 PM UTC
SMARTASSEMBLY & Scrip Navigation
In a smartassembly script, is there a way to tie an IF statement to some type of GOTO command?
KenFarley
May 6, 2026 10:22 PM UTC
If what you refer to as Smartassembly is the product provided by SigMaxim, you’ll really have to talk to them, that’s not a native Creo application.
18-Opal
May 7, 2026 2:52 PM UTC
This should be basic functionality.
You might look at CREOSON if you need more flexibility.
18-Opal
May 15, 2026 1:01 PM UTC
Super impressive automation of Creo Parametric with Claude AI using MCP…
This will only get better - AI will become the expectation soon.
Videos at https://creoson.com
7-Bedrock
May 7, 2026 6:50 PM UTC
SmartAssembly doesn’t use GOTO commands for specific lines within a given tab file.  You can call to a different tab file altogether using the CALL, CALL_EX or INCLUDE functions.
Can I recommend that you post this to our forum on www.sigmaxim.net as the SmartAssembly community is much more involved on that site than here.
Thank You,
Joel Beckley
SIGMAXIM Engineerin Team
Community Moderator
Jun 1, 2026 3:16 PM UTC
Hi ​@Henry_H,
Anurag
