Aug 14, 2019 10:30 AM UTC
Start Parametric from my app
Hi there,
I'm trying to launch and use Parametric in graphic mode from my app (c++ app). The idea is to open Parametric, build a detail through API, close Parametric.
And I can't find a correct way, how to launch Parametric.
Maybe someone faced with a similar task or just know what exact I need to use, read and look? 🙂
Thank you!
RPN
18-Opal
Aug 14, 2019 5:47 PM UTC
Start here ProCore.h
extern ProError ProEngineerStart( char* proe_path,
				 char* prodev_text_path );
  Purpose:  Causes the Creo Parametric TOOLKIT program to spawn and connect to a new
            Creo Parametric session. It is intended for use in simple and
            full asynchronous modes.
On top, you can execute any bat file in Parametric/bin and use your config.pro Smiley Very Happy
Have fun !
