Statically linking C executable for Creo Parametric toolkit
I am using Creo Parametric Release 10.0 and Datecode10.0.4.0
I have written a C executable that will not run unless ucore68.dll is in my Windows path. I want to not be dependent on DLLs if possible.
Here are the errors that I faced:
The code execution cannot proceed because ucore68.dll was not found. Reinstalling the program may fix this problem.
    VladimirNAnswer
    VladimirN24-Ruby IVAnswer
    Same issue - "ucore46.dll is still missing - Creo 4.0": https://community.ptc.com/t5/Customization/ucore46-dll-is-still-missing-Creo-4-0/td-p/886131
    JC_IN_KC10-MarbleAuthor
    Yes, PTC support said that the DLL must be in the path for the executable to run.
