Jun 8, 2010 1:26 AM UTC
Stopping Applications
I have started to create a couple test J-Link applications and every time I exit from Pro/ENGINEER I get a message that the application did not stop correctly. I have a stop method in my code but how do I call it when Pro/E is exiting?
Jun 9, 2010 7:52 PM UTC
Hello Scott
Send me your class that starts your applicaiton and I will help you.
Sep 23, 2010 12:43 AM UTC
This message is not so much for Scott, but for the benefit of
others reading this thread having the same question ....
The "start" and "stop" methods in your J-Link application are
called by Pro/Engineer when it wants to start and/or stop your
program. You shouldn't need to call it yourself.
Not only will calling your "stop" method not stop your app, but
it could also hose up Pro/Engineer in the process.
