2-Explorer
Nov 18, 2015 4:29 AM UTC
Table column width adjustment
I would like to increase or decrease the width of table column based on content into it. My table is repeat region table having BOM details.
Could anyone please help me to know how to achieve the same through toolkit?
I am able to get column width using ProDwgtableColumnSizeGet. I am confused what to do for knowing whether content is fit inside this width or not.
Regards
Ketan
Nov 18, 2015 12:53 PM UTC
Hi Ketan -
I haven't done this myself, so I can only offer suggestions. If your table contains only ProDtlnote entities, you could try the following for each ProDtlnote in the column:
  1. Get the note's line count
  2. Execute ProDtlnoteLineEnvelopeGet on each line number.
  3. For each line envelope:
    1. Get the minimum and maximum X values
    2. Compare this line's minimum/maximum values to those of previous lines.
    3. Save least minimum and greatest maximum X in the column
  4. Compute the minimum column width as the difference of the maximum and minimum X values
  5. Add some padding to the width before resizing the column.
The release notes for Creo Parametric Toolkit 3.0  state that the accuracy of ProDtlnoteLineEnvelopeGet and its related functions now "provide more accurate results":
The following PTC Creo Parametric TOOLKIT functions provide more accurate results:
    •      ProDwgtableRowSizeGet()
    •      ProDrawingTablesUpdate()
    •      ProDtlnoteLineEnvelopeGet()
    •      ProNoteLineEnvelopeGet()
Previously, these functions returned results based on inappropriate character size and these results were inconsistent under different conditions.
This may imply that they don't work very well on Creo 2.0 and earlier.
|+|  M a r k  |+|
2-Explorer
Nov 19, 2015 8:06 AM UTC
Thank you Mark. Unfortunately, I am having Creo 2.0 M090.I would still try this and share results with you.
Thanks and Regards
Ketan
Nov 19, 2015 1:11 PM UTC
Ketan -
Please do give this a try and report your results here. In the meantime, we might hear from someone else who has already worked on this problem.
The section I quoted from the Creo 3.0 Parametric Toolkit Release Notes did not specify when ProDtlnoteLineEnvelopeGet was updated, so it's worth trying on Creo 2.0 M090.
Good luck -
|+|  M a r k  |+|
