2-Explorer
Feb 26, 2016 10:20 AM UTC
Text Symbol into Drawing table using toolkit
I am aware that I can enter text inside drawing table cell using API ProDwgtableTextEnter().
Manually, One can add text symbol into cell of drawing table by following below steps:
  • Double click on cell of drawing table and Note Properties menu will open
  • Click on Text Symbol and Text Symbol menu will open
  • Click on required symbol and click close button
I would like to know how to add text symbol into Drawing table using toolkit.
Thanks in advance!
Regards
Ketan
Feb 26, 2016 6:52 PM UTC
You enter it as ^A (control-A) then the character code for the symbol in question (for example 'n' for diameter) then ^B (control-B).  For example:  "Hole is ^An^B20 mm".  If you are not sure which character is right, make a note using the text symbol palette, and Save Note on it, and examine the resulting file.
2-Explorer
Feb 29, 2016 5:39 AM UTC
Thank you for this suggestion.
I tried with text as "Hole is ^An^B20 mm" through toolkit to write it into table cell. I regenerated drawing sheet also, but it does not change to diameter symbol.
Am I missing something which need to be done?
Thanks and Regards
Ketan
