2-Explorer
The server threw an exception. (Exception from HRESULT: 0x80010105 (RPC_E_SERVERFAULT))
Hi All
I am doing connection to Creo using VB API. We have Creo 4.0 M090. Everything was working fine and we were able to connect to Creo but suddenly application got crashed and some error occurred which I am not sure.
Post this issue, Connection.start API which was working is throwing error as per subject i.e. RPC_E_SERVERFAULT.
Could anyone throw some light on this?
Thanks in advance...!
Regards
Ketan
Hello.
Your application and Creo have the same bit depth (64 or 32 bit)?
Try to reinstall creo if you do not did.
Try after end task the pfclscom.exe in Task manager
2-Explorer
Yes this is what we used to do but this is not the good practice to tell as a solution to end user... Can we do something in exception handling when something fails so that this issue doesnot happen at all in case of any previous Creo app run failed ?
Yes, But You can do the same in your code before starting the creo session.
