Nov 11, 2014 1:18 PM UTC
To export a drw to PDF using J-link
Hello!
Has someone already exported a drw to PDF using J-link?
Thank you!
Nov 14, 2014 7:38 AM UTC
PDFExportInstructions exportInstructions = pfcExport.PDFExportInstructions_Create();
curDrawing.Export("fileName", exportInstructions);
Best Regards,
Nov 17, 2014 11:49 AM UTC
Thanks for the help Tommy Bijnens!
The pdf is opening right after it is generated, do you know if there is any way for it not to open?
In my application, it is not necessary to open the pdf to view.
Thanks!
Nov 17, 2014 7:09 PM UTC
We use this for our PDF export.
PDFOption MyPdfOption = pfcExport.PDFOption_Create();
MyPdfOption.SetOptionType(PDFOptionType.PDFOPT_LAUNCH_VIEWER);
MyPdfOption.SetOptionValue(pfcArgument.CreateBoolArgValue(false));
Myoptions.append(MyPdfOption);
Hope it helps.
Nov 18, 2014 7:46 AM UTC
We use a .DOP file for configuration of the export.
But if you only need to set this one option, Paul's sollution might be more practical.
Nov 18, 2014 11:12 AM UTC
Paul,
Only one question. The "myoptions" attribute is StringBuffer?
At first, this solution did not work as expected.
Thank you!
Nov 18, 2014 1:03 PM UTC
Thank you!
It worked as I expected.
