Aug 9, 2018 2:27 PM UTC
Toolkit C++ : prerequisites for ProIntfimportSourceTypeGet
 I am importing models using ProIntfimportSourceTypeGet() and ProIntfimportModelWithOptionsMdlnameCreate.
Function ProIntfimportSourceTypeGet() works properly on 3 out of 5 machines.
But for same model it returns error on other 2 machines.
Code is same and model to import is same.
My guess : some libs. are missing from those 2 machines. In short there might be some installation gap.
I am sure somebody must have used the import functionality before so
any help would be appreciated.
Aug 12, 2018 2:41 PM UTC
if install issue: Did you try from the UI persepctive?
Also, what type of file do you deal with?
MadhaviG1-VisitorAuthor
Aug 13, 2018 7:19 AM UTC
I can import it manually from UI. But does it use same libraries which are provided for Toolkit?
I am dealing with files from SolidDesigner ( for example with ext. .sdpc)
Aug 13, 2018 2:14 PM UTC
Do you capture the error returned by the function?
