Sep 22, 2016 9:05 AM UTC
Toolkit - colors and appearance
Hi all,
I need via sdk to retrieve the top most color of a surface.
With top most I meen the color of a surface as it look into the current document.
I'm new in CREO terminology so I'll make an example
     1 - You have a PART - cube with one red surface and 5 yellow surfaces
     2 - The part belongs to an assy and the assigned color is green
     3 - The assy could belong to another assy with another colour
If I use the ProSurfaceAppearancepropsGet I retrieve RED/Yellow colour
if I use the ProSurfaceAppearancepropsGet(PART) I retrieve green
BUT I NEED TO RETRIEVE THE VISIBLE COLOR INTO THE CURRENT MODEL
Do you have any suggestion?
thanks everybody
Patrizia
