Oct 8, 2013 6:38 AM UTC
Toolkit: Combined State On Drawing
Good morning,
does anybody know if it's possible to create or modify a drawing view that displays a "combined state"? I am onlyable to find the functions for displaying a simprep or explode state in a drw view.
Thanks.
Andreas
__________________________________
Andreas Hellmann
MCAD Services Pro/E & Pro/E customization
Am Wartfeld 7
D-61169 Friedberg
phone: +49 151 21259910
mail: -
Oct 8, 2013 12:54 PM UTC
Andreas -
Can you tell us which version of Creo you are using? As far as I know,
Pro/Toolkit support for combined states begins on Creo 2.
> that displays a "combined state"? I am only able to find the functions
I couldn't find anything in the Creo 2 Pro/Toolkit documents. You may
want to open a support case with PTC on this question.
I suspect that combined states can only be used with parts and assemblies.
Even though Pro/Toolkit has functions named ProMdlCombStateCreate() and
ProMdlCombstatesGet(), though functions accept arguments of type ProSolid,
not ProMdl. I hope for your sake that I'm wrong about that.
|+| M a r k |+|
Mark Stallard
Rapid Response Development
Business Application Services
Enterprise Services Information Technology
Global Business Services
Raytheon Company
(business)
339-645-6423
(cell)
617-331-5443
235 Presidential Way
Woburn, MA 01801-1060
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this message
in error, please so advise the sender by reply e-mail and delete this
message. Thank you for your cooperation.
FV_01
Feb 16, 2016 6:05 PM UTC
Hi all,
Another question related to combined states in drawings.
Sadly, it looks like there is no API function to get the drawing view's combined state info...
Short of querying drawing view for ProMdl, simprep name, exploded state and view transformation and matching this data with model stored data and making an educated guess it looks like there are no other choices.
As a workaround, does anybody knows how to get output of a drawing view listing similar to the Pro/E UI command 'Drawing View - Display Information on the selected view'. The Pro/E command generated file indeed shows combined state info:
Macro could be written, I guess, but it is not the best approach because Pro/E 'Find' utility cannot be used to select a drawing view and without it one would have to use either a selection buffer or interactive selection which is problematic with synchronous app...
TIA.
Feliks.
andreas hellmann wrote:
Good morning,
Thanks.
Andreas
Andreas Hellmann
Am Wartfeld 7
D-61169 Friedberg
mail: -
