Toolkit Config.pro
Hello all,
I am trying to change a configuration option using C++ toolkit. But I am facing issue to know the correct syntax. Can anybody please provide me with syntax?
tbraxton
tbraxtonAnswer
If you want to change only a single option setting directly without loading files, then consult this article:
Article - CS122393 - How to Get / Set / Restore / Delete a configuration option (single/multivalued) through Toolkit customization in Creo Parametric (ptc.com)
tbraxton
Load a config file with the change to the option(s).
Function ProInputFileRead() with PRO_CONFIG_FILE as file_type to load config file.
Is there no method to change value to one configuration option value from yes to no?
I am trying to change config.pro option value.
tbraxton
tbraxton22-Sapphire IIAnswer
