TOOLKIT: Get a Boundary-Curve from a surface
I want to get a boundary curve from a Creo Parametric 3D-Model surface. Are there any useful methods in Creo Parametric Toolkit you know to get e.g. a vector of boundary curve points of a surface? My idea is to get the boundary curve by clicking on it while my TK-application is running in Creo Parametric.
Thanks in advance,
Florian
You can get the contours from the surface, then list the edges of the contours, then get the 3D datas via GeomCurve's method.
I didn´t find any of these keywords in the "tkuse.pdf" (C-documentation).
Are these methods only available in OTK?
I´m very new to Creo Toolkit so I might just misunderstood something.
Thanks in advance,
Florian
Toolkit C also have these methods but with different name in Core: 3D Geomentry chapter, for the connection issue of showing the Website of community i can't post you the image, you can find it yourself
