Mar 15, 2016 9:09 PM UTC
Toolkit removing old parameters
Updating some old toolkit and getting "CmdMgr action_func '' called for cmd" in the trail file. Trying to remove old parameters and it is not working but gives no error. Any ideas?
Mar 16, 2016 11:57 AM UTC
Hi Earl -
I checked my Creo 3.0 trail files to see whether I had any messages like yours, and I found plenty.
My tools were producing these messages each time I clicked one of the program's menu buttons. Clicking on a menu button invokes an event handler that Creo Parametric Toolkit calls an "action function". To bind these functions to the menu button, you must first create "command" (uiCmdCmdId) using ProCmdActionAdd.
Here's how I would address this problem:
  1. Check your code for a call to ProCmdActionAdd using the string "cmd" as the action name (first argument).
  2. Get the action function (second argument) from that same call to ProCmdActionAdd
  3. Put a break point in the action function and attach the debugger.
  4. Step through the code in the debugger until you find the unexpected behavior.
I hope this helps.
|+|  M a r k  |+|
ebeattie1-VisitorAuthor
Mar 31, 2016 6:31 PM UTC
Thanks Mark,  I will work on this.
