Toolkit start error
I have come with an issue that when I start the protoolkit.dat fie the following error has been shown. I am newbie to this toolkit process and I am learning that think right. Can any one help me with that issue. What mistake I have done?
Thank you
For a complete introduction see those links and the Creo Parametric included API documentation and examples:
[Knowledge Hub] Creo Parametric - Customization
https://www.ptc.com/en/support/article/CS318231
Creo Object TOOLKIT C++ Help Center
https://support.ptc.com/help/creo_toolkit/otk_cpp_pma/r11.0/usascii/
Shipped with every Creo Parametric (select optional API during Creo setup):
OTK:
<Creo Common Files>\otk_cpp_doc\
- "Getting started Guide" (PDF)
- "Release Notes" (PDF)
- "User's Guide" (PDF/HTML)
<Creo Common Files>\otk_cpp_doc\objecttoolkit_Creo\
- "API Wizard"
C TOOLKIT:
<Creo Common Files>\protoolkit\
<Creo Common Files>\protoolkit\protkdoc\
- "API Wizard"
"Release Notes" (RelNotes): important information for each Creo release (new/deprecated/dropped functions)
"User's Guide" (OTKUG/TKUSE): detailed description on API topics; they complement each other – use both!
"API Wizard": function/class listing with function/method details (in/out) and links to examples (if existing)
💡Examples: source code and make files:
<Creo Common Files>\protoolkit\protk_appls\
<Creo Common Files>\otk\otk_cpp\
For OTK & OTK Java & TOOLKIT: Creo UI Editor
<Creo Common Files>\applications\creouieditor\otk_cpp_doc\creo_uifc_ug.pdf
- "Creo User Interface Foundation Classes User Guide"
Ive had this message for a couple different reasons.  Either it cant find the .dll  in your exec_file line, or the folder in your text_dir does not exist.
     Here are a couple long shots it could be:   Possibly your text folder may also be missing the resource and usascii folders.   (or whatever language you use)   or:     your exec_file line is quite long.    I dont know if there is a rule about how many characters you can have, but I woudnt be surprised that if the line exceeded 80 characters it would be invalid.   Try using a destination with a shorter path.
Hi there, Thanks for your response. After changing my location shorter I got another error tab like below,
"pt_inst_test; read error"
And the protoolkit.dat contains that follows
NAME pt_inst_test
EXEC_FILE ./$PRO_MACHINE_TYPE/obj/pt_inst_test.dll
TEXT_DIR ./protk_appls/pt_install_test/text
STARTUP dll
REVISION 18
END
Correct me if I am wrong in that procedure.
Thank you
NAME pt_inst_test
STARTUP dll
REVISION 18
END
Thank you
try using absolute paths without variables in EXEC_FILE and TEXT_DIR lines.
