Oct 11, 2017 10:32 AM UTC
Toolkit VC++ : How to Refresh the Session? Any help would be greatly appreciated.
Need to remove a drawing model from session.
I used ProWindowDelete/ ProWindowCurrentClose to close the Drawing model's window.
Then ProMdlErase to erase it from memory.
But I still get that drawing model in ProSessionMdlList.
If I use ProMdlEraseNotDisplayed to erase it from session then it gives me error. ( may be because  model was already erased)
Please let me know is there any way
to refresh the Session? or
forcefully remove the model from session?
Warm regards,
Madhavi
2-Explorer
Jan 5, 2018 11:57 AM UTC
Give a try with below API sequence and update whether it is working or not:
ProMdlEraseAll
Jan 8, 2018 9:51 AM UTC
Thanks for reply.
But that does not work
2-Explorer
Jan 8, 2018 1:23 PM UTC
Can i know version Nd datecode of Creo you have? I have not tried but I have feeling that previous APIs should solve purpose..
RPN
18-Opal
Jun 13, 2018 9:22 PM UTC
As far I know, you can’t change the current model in a synchronous session. Try to open a object from disk, this one you can change, save and erase if you are done,
