May 18, 2024 1:38 PM UTC
Translation Manager
When I publish to pdf file after the translation package, I get the following error message.
WARNING: [A50920] DITA topic "x-wc://file=0000015385.xml" could not be found for "contentref" at line 6 in "Main Map".
I can also just publish the title. I can't publish contentref
I need to help about this case.
Thank you
Emeritus
May 23, 2024 3:24 AM UTC
Hi @hakdemir,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
