Jun 10, 2014 7:56 PM UTC
Trial 'Fatal error' and no C Drive access
I have got the trial version of creo 2.0 installed successfully and i go to click on the application, it seems to start to load and then 'crashes' with a fatal error. I have scanned this forum for answes to my problem and they seems to involve editing the config.pro file in wordpad. I am stuck at this point, it will not let me save any changes i make to this file. I get a notice that says access to this file was denied. Is there any other way to fix my problem.
P.S.
Attached is the traceback file:
Mahesh_Sharma
22-Sapphire I
Jun 10, 2014 8:42 PM UTC
Matthew,
This seems to be due to graphics. Check information at
http://communities.ptc.com/message/243172#243172
Regarding the config.pro, seems you don't have permission.
You can try:
1. Copy the config.pro to desktop
2. Modify the file on desktop and add the config option enable_opengl_fbo no
3. Save file
4. Copy the modified file from desktp and replace the existing in installation (use paste).
5. It may prompt warning for Copy ....., use Copy and Replace on that.
Mahesh_Sharma
22-Sapphire I
Matthew,
You can try:
3. Save file
Jun 10, 2014 8:49 PM UTC
Brilliant, Thank you. Can i ask what part of the traceback you looked at to determine that the graphics were the issue?
Mahesh_Sharma
22-Sapphire I
Jun 10, 2014 8:54 PM UTC
Traceback files are encrypted hence it will not make any sense for you if you will open and read that.
