Trouble retrieving .gph file.
I am having issues trying to open a UDF from a folder in our Windchill library.
I get this error:
'wtpub://PDM-PD/Libraries/COMMON CAD/CAD Documents/user defined features/90-4118-795-000' does not exist in the database.
Caught exception: com.ptc.wfc.Implementation.pfcExceptions$XToolkitGeneralError
When I dig into the log, it looks like it is failing here:
Exception of type com.ptc.wfc.Implementation.pfcExceptions$XToolkitNotFound
XPFC Message: pfcExceptions::XToolkitNotFound
...at com.ptc.wfc.Implementation.WFCRemoteCommImpl.makeObject line: 5453
If I put the UDF "90-4118-795-000" into my working directory, it executes fine and places the UDF as expected. I have tried to retrieve the UDF in a sandbox code and get the same error, so it seems it is related to .gph files?
I can retrieve .prt files fine, so I am looking for any ideas on how to resolve this issue.
jbryant74Answer
I just noticed there is a typo in the error. The api seems to be placing an \ incorrectly
wtpub://PDM-PD/Libraries/COMMON CAD/CAD Documents/user defined features/SUSPENSION/SCHRADER/CORE INTERFACE ID CAP/\90-4020-795-000' does not exist in the database.
AndrewK
Community Manager
Hi jbryant74,
Thank you for your question.
RPN
18-Opal
Are you sure to have read and download rights for every cad user?
jbryant7412-AmethystAuthorAnswer
RPN
18-Opal
Your URL contains a. couple of blanks, are you encode this with %20?
It turned out to be an input error issue.
Should have been 90-4118-795-000 I was looking for, not 90-4020-795-000.
Works now
