Sep 5, 2013 3:43 AM UTC
Trying to manipulate model parameter using J-Link ... Need help ...
I think I need some advise on J-Link parameter manipulation.
It's supposed to be a very simple function, but I didn't managed to find a solution: To list all pararmeter in a model ,set some of them to a different value and then regenerate this model.
I know there would be a simple way to do that, but through out the internet I only found a Pro/TOOLKIT solution based on C++, any advice about how to implement it with J-Link ?
Thank you !
Sep 19, 2013 11:46 AM UTC
Hi
There is example of J-Link app for parameter edition
PROE_INSTALL_FOLDER\jlink\jlink_appls\jlink_param\source
In common folder, ParamTable.java will help you.
Regards
Vincent
Hi
Regards
Vincent
Sep 20, 2013 12:56 AM UTC
Yeah, that's right, thanks a lot !
I am working on it ~
