2-Explorer
May 15, 2015 1:06 PM UTC
Two-D Repeat Region using ProToolkit
I have simple repeat region and set some relation into it using user defined parameters.
I saved this table and referring to this saved table for all other drawing files using Retrieve table API.
I need Two-D repeat region, which is not implemented into Toolkit. Hence, I saved table and trying to use same in all other drawings using Retrieve table API.
What I am wondering is that how to set different models into Two-D repeat region once table is retrieved in other drawing files using toolkit.
I am open to explain this scenario in more details in case of any query.
Regards
Ketan
