Jun 29, 2015 7:46 AM UTC
U1073 and MSB3073
Hello! I am working with Creo 3,0 and Visual Studio 2012 Update 4. When I build the code, two errors come out.
Error U1073: don't know how to make 'C:/PROGRA~1/PTC/CREO~1.0/M010/COMMON' and error MSB3073: The command "nmake /f make_install dll" exited with code 2.
It may be caused by the wrong value of PROTOOL_SRC. My value ist C:/PROGRA~1/PTC/CREO~1.0/M010/COMMON~1/PROTOO~1. Is it right? Should I set the value of PROE_INSTALL_PATH and its value should be what?
Thank you very much for your help!!
Christian
2-Explorer
Jul 17, 2015 4:17 PM UTC
Hello Christian,
have you been able to solve the issue?
The message don't know how to make 'C:/PROGRA~1/PTC/CREO~1.0/M010/COMMON' hints to a problem with the path to your target file specified.
Obviously the space between Common ans Files is again tripping nmake.  Usually the DOS naming - as you used it - should be OK, so this is strange.
Maybe you can start with a test, simply copying the protoolkit directory into a file structure without blanks in the name and then give it a try from there.
If it works, you know at least that the path is the only issue and you have a working base from where you can experiment to track down the issue.
Gunter
jsu1-VisitorAuthor
Jul 20, 2015 11:07 AM UTC
Hello, Gunter,
thank you for your reply. This address is already the DOS address. Because I want Creo to work in asynchronous way, so the setting is different. I have modified my setting, in fact I am not very clear what the options mean in the setting. Finally it works.....
I will post a new question, if you have time, could you have a look and may you are also interested.
Christian
