2-Explorer
Nov 30, 2017 11:34 AM UTC
UI dialog style in Toolkit
Hello
Can anyone suggest me document related to UI dialogue style set into Toolkit? I would like to explore different option available into API ProUIDialogDialogstyleSet(). What does each option of argument ProUIDialogStyle represents?
Thanks in advance. Any help would be of great help.
Regards
Ketan
Dec 4, 2017 8:19 AM UTC
Hi @Ketan_Lalcheta
creo4_m010_tkuse.pdf ( Creo Parametric TOOLKIT User's Guide) has details on DialogStyle. Page# 329, 407.
Warm regards,
Madhavi
Dec 4, 2017 8:22 AM UTC
FYI:
The following are the dialog style
types supported by Creo
Parametric TOOLKIT :
1. Modal type with respect to its
parent Dialog =
PROUIDIALOGSTYLE_
PARENT_MODAL; This should be
the value for all dialogs except
those involving progress bars.
2. A transient dialog type is used
only to display some state
information, usually referring to
the progress of some kind of
lengthy operation =
PROUIDIALOGSTYLE_
WORKING; This should be the
value for dialogs with progress
bars.
Other dialog style values are not
currently supported for Creo
Parametric TOOLKIT dialogs.
2-Explorer
Dec 5, 2017 11:03 AM UTC
Thank you so much. It helped. Actually I thought changing ui dialog style will allow me to activate "Datum Display Filters" even though dialog is active.
Any idea on how to achieve the same?
Thanks and Regards
Ketan
