Apr 1, 2014 6:46 AM UTC
Unable to open Protoolkit help file.
Hi
I don't whether this question is already answered or not.
I am trying to open protoolkit API help document (index.html) located in protkdoc directory.
But everythime it fails with AccessControlException "access denied ("java.io.FilePermission" "C:\Program Files\PTC\Creo 2.0\Common Files\M070\protoolkit\protkdoc\images\PTCLOGO\ptclogo.gif" "read")"
Tried running IE in admin mode, but same result.
Can anybody help me to get this resolved. I am using Win7 64 bit. Creo 2.0 M70
the detailed log is :
Java Plug-in 10.51.2.13
Using JRE version 1.7.0_51-b13 Java HotSpot(TM) Client VM
User home directory = C:\Users\sandeep.kavade
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
CacheEntry[file:/C:/Program%20Files/PTC/Creo%202.0/Common%20Files/M070/protoolkit/protkdoc/APIWizardStartup.jar]: updateAvailable=false,lastModified=Wed Aug 28 09:10:39 IST 2013,length=2459
0
# Swing Found.
CacheEntry[file:/C:/Program%20Files/PTC/Creo%202.0/Common%20Files/M070/protoolkit/protkdoc/APIWizardUI.jar]: updateAvailable=false,lastModified=Wed Aug 28 09:10:39 IST 2013,length=91030
Reseting Vectors
Error dfdasfdsfdsfsd:java.security.AccessControlException: access denied ("java.io.FilePermission" "C:\Program Files\PTC\Creo 2.0\Common Files\M070\protoolkit\protkdoc\config.TXT" "read")
Error in reading Configuration File
Error dfdasfdsfdsfsd:java.security.AccessControlException: access denied ("java.io.FilePermission" "C:\Program Files\PTC\Creo 2.0\Common Files\M070\protoolkit\protkdoc\msg.TXT" "read")
Error in Reading Message File
Errorjava.security.AccessControlException: access denied ("java.io.FilePermission" "C:\Program Files\PTC\Creo 2.0\Common Files\M070\protoolkit\protkdoc\api.IDX" "read")
at java.security.AccessControlContext.checkPermission(Unknown Source)
at java.security.AccessController.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkPermission(Unknown Source)
at sun.plugin2.applet.AWTAppletSecurityManager.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkRead(Unknown Source)
at java.io.File.isDirectory(Unknown Source)
at sun.net.www.protocol.file.FileURLConnection.connect(Unknown Source)
at sun.net.www.protocol.file.FileURLConnection.getInputStream(Unknown Source)
at java.net.URL.openStream(Unknown Source)
at API_DataManager.init_readAPITreeFile(API_DataManager.java:300)
at API_DataManager.<init>(API_DataManager.java:249)
at apiwizard.init(apiwizard.java:67)
at com.sun.deploy.uitoolkit.impl.awt.AWTAppletAdapter.init(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Foreground = sun.swing.PrintColorUIResource[r=51,g=51,b=51]
Jul 25, 2014 3:12 PM UTC
I have something. I found the cause of this problem. Need to use Java version 1.6 instead 1.7. I made virtual machine based on Windows 7 with Java 1.6 and Internet Explorer 8. And all works fine.
You can download Java 1.6 by this link.
Mahesh_Sharma
22-Sapphire I
Apr 1, 2014 3:01 PM UTC
Hi Sandeep,
This issue may occur due to Changes to JRE Security Dialogs. For detailed information refer below articles.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS130577
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS133402
I hope this will answer your query.
Mahesh
Apr 2, 2014 1:31 PM UTC
Hi Mahesh,
Thanks for reply. The links provided talk about JRE 7 Upate 21 and Update 25.
I am not aware of how to start apiwizard in webserver. But thanks for the reply.
Apr 2, 2014 12:44 PM UTC
Apr 2, 2014 1:32 PM UTC
Hi Sergey Dobrovsky,
Thanks for reply. This is a nice work around. Now I have something which I can refer to.
Jul 24, 2014 5:51 PM UTC
Hello to all
I have the same problem. Вге I do not have access to the links shown above. What can I do with Java settings to open protoolkit help? Please, anybody help me ))
