Unlocking this application requires option TOOLKIT-for-3D_Drawings
I was trying to unlock my Async  application then this msg shown.
Command I use:
protk_unlock.bat myapp.exe
Command I use:
check whether your license contain feature number 222 (TOOLKIT-for-3D_Drawings).
TOOLKIT-for-3D_Drawings is a nightmare.  It's embedded into the pt_examples and I cannot get PTC to remove those calls.  They even claim that for version 7.0.3 there is no problems, but I still see it.  I cannot unlock pt_examples without that license. Do not recompile pt_example.dll because it will be locked and you don't have a way to removed a lock if you don't have this license.
Does anyone know when this TOOLKIT-for-3D_Drawings license was established?  I see no other way but to choose Creo before that to recompile pt_examples that I can use work work later.
please ask PTC Support directly.
