Nov 30, 2012 8:33 PM UTC
Upgrading JLink Apps for Creo 2
Hi Everyone -
I have two JLink applications to test on Creo 2. Has anyone had
any success - or failure - at this recently?
I already know from Bjarne Franden's comments that the ribbon UI
will require extra attention. I'm particularly concerned, though,
about reading drawing sheets, symbols and tables. Can anyone
comment on JLink drawing support in Creo 2?
Thanks in advance -
|+| M a r k |+|
Mark Stallard
Rapid Response Development
information Solutions
Integrated Defense Systems
Raytheon Company
(business)
+1.339.645.6423
(cell)
+1.617.331.5443
(tie line)
224.6423
235 Presidential Way
Woburn, MA 01801-1060
www.raytheon.com
Raytheon Sustainability
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this message
in error, please so advise the sender by reply e-mail and delete this
message. Thank you for your cooperation.
Dec 3, 2012 12:41 PM UTC
Hi Mark,
I updated already three JLink applications to Creo 2 and had no real problems.
I followed the description from JD Felco, see here: http://www.felcosolutions.com/JLinkRibbon.pdf.
I had only one issue with a tool that regenerates the modelin Creo. If the config option regen_failure_handling is not set to resolve_mode, the regeneration fails.
A other application changes the frame on a drawing and moves tables on the drawing, I was able to reuse the old code to change the frame and find/move the tables.
Michael Holzwarth
Global IT PDP Modeling Solutions Region 2
John Deere GmbH & Co. KG
John Deere Werk Mannheim
John-Deere-Str. 90 • 68163 Mannheim • Germany
Dec 3, 2012 4:04 PM UTC
We like to run Creo 2.0 with no resolve mode, so I toggle it from J-Link whenever I need to regenerate with code like this:
//Activate resolvemode to allow regeneration
session.SetConfigOption("regen_failure_handling", "resolve_mode");
((Solid) model).Regenerate(null);
session.SetConfigOption("regen_failure_handling", "no_resolve_mode");
Planning the RibbonUI can take some time. I define a J-LINK tab and placeholder groups in creo_parametric_admin_customization.ui for every needed mode.
Then each J-Link application adds itself to a group upon launch with its ribbon.ui file for relevant modes. This way no J-Link application is dependent on others defining UI first. The protkdat order in config.pro defines the ordering inside the groups though.
I have converted 15 J-link apps and have only modified the initiation according to JDs description as well. A few apps have been retired due to improved functionality in Creo as well.
/Bjarne
