Jul 5, 2013 10:14 AM UTC
Upgrading my VBA code to Creo 2.0
Hi
Im trying to upgrade some old VB.NET applications to Creo 2.0
When adding the new Creo Parametric Type Library to my project i get into some problems.
Where is the pfcls namespace?
Has it been replaced with the pfc namespace?
Where is the IpfcAsyncConnection class?
What am i missing here??, has PTC changed the VB API without updating the documentation??
Nov 7, 2013 8:41 PM UTC
Why to change the namespace name, I have to update all my code?
Anyone can help on this changes?
Jan 31, 2014 5:28 PM UTC
Accordingly do vbug.pdf manual distributed with Creo:
To register the COM server, run the
vb_api_register.bat file located at <creo_loadpoint>/Parametric/bin
Try to run this bat file and all class libraries for VBA should return as expected.
Beware that with Creo2 you need a custom installation to include VB support.
Hope this helps,
Apr 30, 2015 9:11 AM UTC
I confirm that the option is available in a custom installation of CREO 2.0 form DVD
