Use ProUIDalogExit to close the dialog box, but it does not work.
Hello, I would like to ask you a question about using the creatolkit dialog box.
You are using the dialog box by creating a dialog with ProUIDialogCreate and enabling it with ProUIDialogActivate.
The feature I created was considered to open the dialog box periodically, so I don't want to use ProUIDialogDestroy and I want to close the dialog only with ProUIDialogExit.
However, there is a problem that the dialog box does not close when using ProUIDalogExit.
The code says PRO_TK_NO_ERROR is returned and error-free. Code progression is also running correctly out of ProUIDialogActivate, but the dialog does not close on the screen.
If you know anything about this situation, I would appreciate your help.
Below is a partial reference code attached.
Thank you.
// Functions to run when the Cancel button is pressed
void OnCancelButtonClicked(char* dialog, char* component, ProAppData data)
	ProError status = PRO_TK_NO_ERROR;
	if (list_nameset != NULL)
		ProArrayFree((ProArray*)&list_nameset);
	if (list_labelset != NULL)
		ProArrayFree((ProArray*)&list_labelset);
	if (file_display_mdl != NULL)
		ProArrayFree((ProArray*)&file_display_mdl);
	if (selcections_wlist != NULL)
		ProArrayFree((ProArray*)&selcections_wlist);
	if (selcections_clist != NULL)
		ProArrayFree((ProArray*)&selcections_clist);
	if (out_promdl != NULL)
		ProArrayFree((ProArray*)&out_promdl);
	//Close the dialog
	status = ProUIDialogExit(dialog, PRO_TK_NO_ERROR);
	if (status != PRO_TK_NO_ERROR) {
		printf("대화 상자 닫기 오류: %d\n", status);
		return;
ProError MyCustomActionCallback(uiCmdCmdId cmd_id, ProAppData data)
status = ProArrayAlloc(0, sizeof(wchar_t**), 1, (ProArray*)&selcections_wlist);
	status = ProArrayAlloc(0, sizeof(char**), 1, (ProArray*)&selcections_clist);
	status = ProArrayAlloc(0, sizeof(ProMdl), 1, (ProArray*)&out_promdl);
		iMessageBox(L"ProMdl 함수에서 오류 발생.");
	//UI 활성화
	status = ProUIDialogActivate(DIALOG_NAME2, NULL);
		iMessageBox(L"Acticate_ERROR");
	status = ProUIDialogExit(DIALOG_NAME2, PRO_TK_NO_ERROR);
	return PRO_TK_NO_ERROR;
//FUNCTION : user_initialize()
extern "C" int user_initialize(
	int argc,
	char* argv[],
	char* version,
	char* build,
	wchar_t errbuf[80])
	uiCmdCmdId custom_action_id;
	ProFileName msgfile;
	UIsetting();
	status = ProCmdActionAdd("MyCustomActionCallback", (uiCmdCmdActFn)MyCustomActionCallback, uiProe2ndImmediate, NULL, PRO_B_TRUE, PRO_B_TRUE, &custom_action_id);
	status = ProCmdIconSet(custom_action_id, "3P_1.png");
	status = ProCmdDesignate(custom_action_id, "DRAWING", "run_help", "run_help", msgfile);
	return 0;
