Jul 17, 2018 9:05 AM UTC
Using Creo in VPN
Do I have to use Creo from home via VPN client, which ports should I enable to use?
DomenicLaritz
Jul 17, 2018 10:42 AM UTC
According to PTC article CS110511 ("List of executables and port numbers that need to be added to the Windows Firewall exceptions list for Flex enabled products") only the license manager port (usually 7788) needs an exception.
