Oct 31, 2011 8:16 PM UTC
Using Pro/Toolkit with Visual Studio 2010
Hi Everyone -
The Pro/Toolkit docs on Creo Elements/Pro 5 (aka Wildfire 5) say that
Microsoft
Visual Studio 2008 is required for building toolkit applications. I have
versions
2003, 2005 and 2010, but not 2008.
Has anyone built a Pro/Toolkit application on Visual Studio 2010 yet? I'd
rather
not spend a day chasing linker errors just to learn that the two are
incompatible.
|+| M a r k |+|
Mark Stallard
Rapid Response Development
information Solutions
Integrated Defense Systems
Raytheon Company
(business)
+1.978.436.6016
(cell)
+1.617.331.5443
(tie line)
239.6016
880 Technology Drive
Billerica, MA 01821
www.raytheon.com
Raytheon Sustainability
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this message
in error, please so advise the sender by reply e-mail and delete this
message. Thank you for your cooperation.
Nov 1, 2011 11:51 AM UTC
Hey Mark,
We are on Creo Elements/Pro 5.0 and we are using MSVC 2008. PTC supports the compiler, linker, libraries and header files that were shipped with MSVC 2008. However; that doesn't mean that you have to have MSVC 2008. You CAN build Creo Elements/Pro 5.0 compatible programs using the Express version of the IDE and the correct Windows SDK. If you don't want to go that route then I would suggest getting a full copy of MSVC 2008.
I would not expect the 2010 version to be compatible with Creo Elements/Pro 5.0 because PTC compiles their libraries with 2008. Between 2008 and 2010 Microsoft has changed the core C/C++ runtime libraries which would not be backwards compatible with the PTC libraries that were built with 2008.
Patrick Williams | Engineering Systems | o: 616.698.3766 | c: 616.947.2110
[cid:image001.jpg@01CC986B.1C97E120]
