Feb 18, 2025 6:35 AM UTC
VARIABLE TEXT IN CUSTOM SYMBOL c++ code
Hi I want to add variable text to a custom symbol programmatically.
Emeritus
Feb 18, 2025 6:57 AM UTC
Hello @RD_12909834,
Thank you for your question.
I'd like to recommend to bring more details and context to your initial inquiry.
  1. Have you already tried any methods or approaches to add variable text to the custom symbol using C++? If so, what were the results?
  2. Are you encountering any specific error messages or issues when trying to implement this feature?
It also helps to have screenshot(s) to better understand what you are trying to do in your process. Adding more context will increase your chances to receive meaningful help from other Community members.
Vivek N
Community Moderation Team.
Feb 18, 2025 7:12 AM UTC
This is my code and it is not giving any error but not updating the
// load symbol file
pfcDetailSymbolDefItem_ptr symDef = pfcDwg->RetrieveSymbolDefItem("dim_balloon", pfcDetailSymbolDefItemSource::pfcDTLSYMDEF_SRC_PATH, strr, NULL, true);
pfcDetailSymbolInstInstructions_ptr instrs = pfcDetailSymbolInstInstructions::Create(symDef);
pfcDetailVariantText_ptr mtext = pfcDetailVariantText::Create("inValue", xstring::Printf("%d", k + 1));
dims = dimname.c_str();
pfcDetailVariantTexts_ptr stext = pfcDetailVariantTexts::create();
stext->append(mtext);
pfcFreeAttachment_ptr freeAttachmentpos = pfcFreeAttachment::Create(src_loc);
pfcView2D_ptr view2d;
view2d = pfcView2D::cast(model2D->GetViewByName("Primary View"));
freeAttachmentpos->SetView(view2d); // #
freeAttachmentpos->SetAttachmentPoint(src_loc);
pfcAttachment_ptr attach = pfcAttachment::cast(freeAttachmentpos);
instrs->SetInstAttachment(pfcSymbolDefAttachmentType::pfcSYMDEFATTACH_FREE);
instrs->SetTextValues(stext);
Regards
Feb 18, 2025 7:13 AM UTC
This is not updating the symbol note
Feb 18, 2025 7:49 AM UTC
contact PTC Support.
