VB API cast selected table to ITable
I am doing a little program in which the user will select a table in a drawing, and then the program will read that table and extract information and do stuff with it.
My problem is that I can't figure out how to cast the selected object to a table object.
Here's how I launch the selection process:
	Private Sub BtnSelectTable_Click(sender As Object, e As EventArgs) Handles BtnSelectTable.Click
		Try
			Dim SelectedTable As IpfcSelections = SelectFeatures(theBaseSession)
			For i = 0 To SelectedTable.Count - 1
				Dim CurrTbl As IpfcTable = SelectedTable.Item(i)
				MsgBox(CurrTbl.GetRowCount)
			Next
		Catch ex As Exception
			MsgBox(ex.Message & vbNewLine & vbNewLine & ex.StackTrace,, GetCurrentMethod().Name)
		End Try
	End Sub
Here's how I select the drawing table (comes from the PTC supplied example):
	Public Function SelectFeatures(ByVal session As IpfcBaseSession) As IpfcSelections
		Dim selections As IpfcSelections
		Dim selectionOptions As IpfcSelectionOptions
		Try
			'Selection options are set to select only features with a specified max
			'number.
			selectionOptions = (New CCpfcSelectionOptions).Create("dwg_table")
			selections = session.Select(selectionOptions, Nothing)
			SelectFeatures = selections
			MsgBox(ex.Message.ToString + Chr(13) + ex.StackTrace.ToString)
			Return Nothing
		End Try
	End Function
I can confirm that the selection works, if I select somethings I can get a correct COUNT of how many object I have selected.
The problem is that when I try to cast the selected object to any kind of table object to be able to work with it I get casting error:
Any idea?
AlexCoteAnswer
Finally found something that works ...
		Try
				Dim TmpCurrTbl As IpfcSelection = SelectedTable.Item(i)
				Dim CurrTbl As IpfcTable = TmpCurrTbl.SelItem
			Next
		End Try
	End Sub
The "SelectedTable.Item(i)" is returning an object of type IpfcSelection (notice the missing S at the end). This object then return an handle to the item, and can be set to the type of object you need.
AlexCote1-VisitorAuthorAnswer
		Try
			Next
		End Try
	End Sub
