Feb 19, 2020 12:17 PM UTC
.vb file called trough a mapkey - fails
To all
I am trying to learn CREO customisation so I am "playing" around with mapkey + .vb file.
I set up a mapkey 'OS Script' option pointing to a .vb file containing a simple test program. If I press 'run' I can see the command DOS window being open but then I get a request to select the app (windows 10) to run the .vb file. So far I have not found anything in the vbapi doc on the matter. How does one run any of the vbapi examples provided?
Regards
Feb 20, 2020 11:04 AM UTC
@JBlackhole wrote:
To all
Regards
please upload your simple test .vb program and describe its functionality.
Feb 20, 2020 11:07 AM UTC
... and tell us installed Creo version.
Feb 20, 2020 3:34 PM UTC
Creo 5
Any program will do. Maybe the standard "Hello World" either displayed to a msgbox or in the status bar
something like that?
Public Class test1
 Public Sub mytest1
	Dim TheSession As pfcls.IpfcSession
	Dim message As Istringseq
	 message = New Cstringseq
	 message.Set(0, "Hello World")
	TheSession.UIDisplayMessage("Title", "a message", message)
	Msgbox("Hello World")
End Class
