Mar 20, 2013 10:21 AM UTC
VB.Net and Pro/Toolkit Interoperability
Dear Pro/E Experts,
Is there a way we can call some Pro/Toolkit function from a C dll in VB.Net application and have this Pro/Toolkit API perform some operation in Pro/Engineer.
Basically what i am trying to do is
  1. Create a VB.Net application for customizing Pro/Engineer.
  2. I understand that there are some limitations of using Pro/Engineer VB API's, example the API's required for feature creation and manipulation are not available (UDF's may be an exception). So i want to write some methods in a C dll using Pro/Toolkit and call them from VB.Net.
Is this kind of interoperability between VB.Net and Pro/Toolkit is possible and are there any limitations?
I request someone to provide some guidance on this or an example if available.
Appreciate your support!
Best Regards,
Prudvi
