Mar 21, 2013 1:26 AM UTC
VB.Net and Pro/Toolkit Interoperability
Is there a way we can call some Pro/Toolkit function from a C dll in VB.Net application and have this Pro/Toolkit API perform some operation in Pro/Engineer.
Basically what i am trying to do is
  1. Create a VB.Net application for customizing Pro/Engineer.
  2. I understand that there are some limitations of using Pro/Engineer VB API's, example the API's required for feature creation and manipulation are not available (UDF's may be an exception). So i want to write some methods in a C dll using Pro/Toolkit and call them from VB.Net.
Is this kind of interoperability between VB.Net and Pro/Toolkit is possible and are there any limitations?
I request someone to provide some guidance on this or an example if available.
Appreciate your support!
Best Regards,
Prudvi
Mar 21, 2013 2:24 AM UTC
Look at the functions ProToolkitTaskExecute() and ProToolkitDLL*().
Bob Monat
Jerand Technical Services, Inc.
bob@jerand.com
www.jerand.com
1-317-875-6087
Mar 21, 2013 5:05 AM UTC
Hi Bob,
My requirement is to call Pro/Toolkit custom dll functionsfrom VB.Net application.
As per documentation, ProToolkitTaskExecute() and ProToolkitDLL*() are same Pro/Toolkit functions to call another Pro/Toolkit custom dlls.
Best Regards,
Prudvi
8-Gravel
Mar 21, 2013 6:19 AM UTC
Hello Prudvi!
Yes it is possible. A long time agoI wrote a Win32-Dll that exports functions to use in VB6.0.
I used that in Wildfire 3.0 cause I don't like the managed extension of VS2003.
Now using Wildfire 4.0 with VS2005 it is possible to write managed code for .NET 2.0.
You have to use C++/CLI and write wrapper classes for your toolkit funktions.
So you can use VB.NET or C#.
Greetings Lars
Mar 21, 2013 9:12 AM UTC
It's easy to execute toolkit functions from VB.
See chapter "
Andreas
__________________________________
Andreas Hellmann
MCAD Services Pro/E & Pro/E customization
Rudolf-Diesel-Str. 6
D-65439 Floersheim / Germany
phone: +49 6145 598296
mail: -
Mar 21, 2013 11:32 AM UTC
Hello Lars and Andreas,
Thanks foryour reply. I will check the method you suggested.
Have a great day!
Best Regards,
Prudvi
Jun 25, 2015 4:04 PM UTC
I am doing the same work now.
