1. "Creo VB API Example code to export a part model to 3D DXF Format in Creo Parametric ": https://www.ptc.com/en/support/article/CS247215
Quote: "Creo Parametric VB API Users may refer to below provided example C# function":
static internal bool ExportToDXF3D(string strFile, string strDXF, IpfcAsyncConnection conn)
if (string.IsNullOrEmpty (CreoPath)) return false;
IpfcModel model = null;
try {
var session = conn.Session as IpfcBaseSession;
var dxfexp = (new CCpfcDXF3DExportInstructions ().Create ()) as IpfcDXF3DExportInstructions;
int type = (int)EpfcModelType.EpfcMDL_PART;
var modelDesc = new CCpfcModelDescriptor ().Create (type, strFile, null);
model = session.RetrieveModelWithOpts (modelDesc, new CCpfcRetrieveModelOptions().Create ());
try {
var exi = dxfexp as IpfcExport3DInstructions;
var triangOptions = (new CCpfcTriangulationInstructions().Create(0.10000, 0.500000)) as IpfcTriangulationInstructions;
triangOptions.StepSize = 0.5;
exi.set_TriangulationOptions(triangOptions);
var new_exi = exi as IpfcExportInstructions;
model.Export (strDXF, new_exi);
} catch (COMException ex) {
var ex2 = Marshal.GetExceptionForHR (ex.ErrorCode);
Console.WriteLine (ex2.Message);
return false;
return true;
} finally {
try { if (model != null) model.Erase (); } catch { }
conn.Close ();
return false;
2. "Example code to export (Save As) a drawing file to PDF format through Creo Parametric VB API": https://www.ptc.com/en/support/article/CS141963
Quote: "Example code to export Active drawing model to PDF format with Stroke All Fonts, Monochrome and do not check Open file in Acrobat Reader options defined":
Sub Main2()
Dim asynconn As New pfcls.CCpfcAsyncConnection
Dim conn As pfcls.IpfcAsyncConnection
Dim CreoSession As pfcls.IpfcBaseSession
Dim CreoCurrentModel As pfcls.IpfcModel
Set conn = asynconn.Connect("", "", ".", 5)
Set CreoSession = conn.session
MsgBox "This is the current Working Directory: " & vbCrLf & CreoSession.GetCurrentDirectory
Set CreoCurrentModel = CreoSession.CurrentModel
MsgBox "Model name = " & CreoCurrentModel.FullName
Dim oWindow As IpfcWindow
Set oWindow = CreoSession.GetModelWindow(CreoCurrentModel)
oWindow.Activate
Dim PDFExportInstrCreate As New CCpfcPDFExportInstructions
Dim PDFExportInstr As IpfcPDFExportInstructions
Set PDFExportInstr = PDFExportInstrCreate.Create
Dim PDF_Options As New pfcls.CpfcPDFOptions
Dim PDFOptionCreate_SAF As New CCpfcPDFOption
Dim PDFOption_SAF As IpfcPDFOption
Set PDFOption_SAF = PDFOptionCreate_SAF.Create
PDFOption_SAF.OptionType = EpfcPDFOptionType.EpfcPDFOPT_FONT_STROKE
Dim newArg_SAF As New CMpfcArgument
PDFOption_SAF.OptionValue = newArg_SAF.CreateIntArgValue(EpfcPDFFontStrokeMode.EpfcPDF_STROKE_ALL_FONTS)
Call PDF_Options.Append(PDFOption_SAF)
Dim PDFOptionCreate_CD As New CCpfcPDFOption
Dim PDFOption_CD As IpfcPDFOption
Set PDFOption_CD = PDFOptionCreate_CD.Create
PDFOption_CD.OptionType = EpfcPDFOptionType.EpfcPDFOPT_COLOR_DEPTH
Dim newArg_CD As New CMpfcArgument
PDFOption_CD.OptionValue = newArg_CD.CreateIntArgValue(EpfcPDFColorDepth.EpfcPDF_CD_MONO)
Call PDF_Options.Append(PDFOption_CD)
Dim PDFOptionCreate_LV As New CCpfcPDFOption
Dim PDFOption_LV As IpfcPDFOption
Set PDFOption_LV = PDFOptionCreate_LV.Create
PDFOption_LV.OptionType = EpfcPDFOptionType.EpfcPDFOPT_LAUNCH_VIEWER
Dim newArg_LV As New CMpfcArgument
PDFOption_LV.OptionValue = newArg_LV.CreateBoolArgValue(False)
Call PDF_Options.Append(PDFOption_LV)
PDFExportInstr.FilePath = "D:\" & CreoCurrentModel.FullName & ".pdf"
PDFExportInstr.Options = PDF_Options
CreoCurrentModel.Export PDFExportInstr.FilePath, PDFExportInstr
conn.Disconnect (2)
Set asynconn = Nothing
Set conn = Nothing
Set session = Nothing
Set oModel = Nothing
End Sub
