VBA GTOL
To my surprise I found an item type of GTOL, having trouble figuring out what to set gtol to...
Set gtols = hole.ListSubItems(EpfcModelItemType.EpfcITEM_GTOL)
     Dim gtol as Ipfc????
Any help would be greatly appreciated!
Not sure that you can get GTOL using this method
Function ListSubItems (Type as IpfcModelItemType [optional]) as IpfcModelItems [optional]
Lists the component model items that make up the feature.
Following are the subitems that can get listed with this method: ITEM_SURFACE, ITEM_EDGE, ITEM_QUILT, ITEM_CURVE, ITEM_POINT, ITEM_AXIS, ITEM_COORD_SYS and ITEM_DIMENSION.
Manual References:
ModelItem: Getting ModelItem Objects, ModelItem: Getting ModelItem Objects
Parameters:
Type
The type of subitem you want to find
Returns:
The list of subitems of the specified type
