Jul 28, 2016 1:33 PM UTC
VBA scripting in CREO
In all the PTC/CREO suport materials, are there examples of using Excel's VBA to drive repetative operations in CREO?  Thank you.
    Chris3
    Jul 29, 2016 2:30 PM UTC
    When you say "repetitive operations" what are you referring to?
    You can use Excel to drive geometry:
    http://learningexchange.ptc.com/tutorial/188/creating-an-ms-excel-analysis-feature
    Creo 2.0 e Excel - YouTube
    You can also use VBA to interact with the VB Toolkit. This can be complicated to setup and is not entirely user friendly.
    Creating a Creo2 Tool with Toolkit
    Examples: <load_point>\Common Files\<Datecode>\protoolkit
    Alternatively you can record a mapkey and then edit the mapkey to suit your needs.
