May 11, 2012 6:56 PM UTC
Wavy washer optimization with mechanica
We want to optimize a washer using mechanica. However the Relation
"sin(trajpar * 360 *8)*.5" does not have a good way to interface with
parameters. Is there jlink or proprogram or otherwise optimize-able way to
do this?
regards,
Alfonso
May 11, 2012 7:27 PM UTC
I think that the contact surface changes under compression are going to
cause some serious problems if you are going to analyze the spring
itself. Also the spring will be undergoing 'self contact'. This
usually causes major headaches for strictly mechanical (linear FEA
code). Think of a bellows collapsing and folding in on itself without
violating the boundary of the 3D geometry.
I don't use Mechanica specifically, so I don't know its' non-linear
capabilities, but these are the things to watch out for.
Christopher F. Gosnell
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
